跳转到主内容
Nest Dropcam Pro Motherboard Replacement
你所需要的
  1. Nest Dropcam Pro Motherboard Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Motherboard Replacement: 步骤 2 中的图像 1,2 Nest Dropcam Pro Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Motherboard Replacement: 步骤 3 中的图像 1,2 Nest Dropcam Pro Motherboard Replacement: 步骤 3 中的图像 2,2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Nest Dropcam Pro Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Motherboard Replacement: 步骤 5 中的图像 1,2 Nest Dropcam Pro Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Motherboard Replacement: 步骤 6 中的图像 1,2 Nest Dropcam Pro Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Motherboard Replacement: 步骤 7 中的图像 1,2 Nest Dropcam Pro Motherboard Replacement: 步骤 7 中的图像 2,2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
结论
7等其他人完成本指南。
David Foens
于09/03/15注册
893 声望
创作了6篇指南
团队
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G4
3 名成员
创作了12篇指南
7条评论
where we can get the mother board to replace
fercervantes - 回复
I need this too
kundimberi -
Where can I get the motherboard
xtogamba - 回复
Can't find it either. Silly to write an entire article for credit if parts arent actually available.
Bruce Weissman - 回复
searched for the MB online?? Why no mention of where to get it??
anonymous 6761 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 8,680
