简介
This guide is needed to replace the Micro-USB port if the Nest Dropcam Pro is plugged in but not receiving power. Make sure the device is unplugged before opening.
你所需要的
Press in the mounting clips on each side of the case to remove the camera from the mount.
Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
Lift the Micro-USB port away from the motherboard.
4等其他人完成本指南。
4条评论
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Did it work for you?
Where can you order the micro-usb charge port for this cam?
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
