跳转到主内容
Nest Dropcam Pro Camera Lens Replacement
你所需要的
  1. Nest Dropcam Pro Camera Lens Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Camera Lens Replacement: 步骤 2 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Camera Lens Replacement: 步骤 3 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement: 步骤 3 中的图像 2,2
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Camera Lens Replacement, Motherboard: 步骤 4 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Camera Lens Replacement: 步骤 5 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement: 步骤 5 中的图像 2,2
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Camera Lens Replacement: 步骤 6 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement: 步骤 6 中的图像 2,2
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Camera Lens Replacement: 步骤 7 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement: 步骤 7 中的图像 2,2
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Camera Lens Replacement, Camera Lens: 步骤 8 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement, Camera Lens: 步骤 8 中的图像 2,2
  9. Nest Dropcam Pro Camera Lens Replacement: 步骤 9 中的图像 1,3 Nest Dropcam Pro Camera Lens Replacement: 步骤 9 中的图像 2,3 Nest Dropcam Pro Camera Lens Replacement: 步骤 9 中的图像 3,3
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
  10. Nest Dropcam Pro Camera Lens Replacement: 步骤 10 中的图像 1,2 Nest Dropcam Pro Camera Lens Replacement: 步骤 10 中的图像 2,2
    • Lift up the foam cover to reveal a second screw underneath.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws.
  11. Nest Dropcam Pro Camera Lens Replacement: 步骤 11 中的图像 1,1
    • With the screws gone, lift the camera lens away from the remaining components.
结论
2等其他人完成本指南。
David Foens
于09/03/15注册
893 声望
创作了6篇指南
团队
USF Tampa, Team 15-4, Blackwell Fall 2015 USF Tampa, Team 15-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S15G4
3 名成员
创作了12篇指南
2指南评论
Where do you get replacement lens?
Jim Fischer - 回复
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 4,018
