跳转到主内容
Nest Cam Speaker Replacement
你所需要的
  1. Nest Cam Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Speaker Replacement: 步骤 2 中的图像 1,1
    • Open the back panel completely to expose the speaker indicated by the red circle.
  3. Nest Cam Speaker Replacement: 步骤 3 中的图像 1,3 Nest Cam Speaker Replacement: 步骤 3 中的图像 2,3 Nest Cam Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove old speaker gently with a spudger.
    • When placing the new speaker in make sure the prongs are facing the right direction and will connect with the two connector points on the motherboard.
结论
另外一个人完成了本指南。
Jade Weiss
于02/24/16注册
662 声望
创作了3篇指南
团队
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G1
7 名成员
创作了10篇指南
4条评论
where can I buy the new replacement speaker part?
Bradley Kang - 回复
Anyone find out the answer to Bradley's question?
Ravi - 回复
I’m curious as well if anyone has found where to obtain replacement/repair parts. Should be simple enough if we can determine the part number of the speaker.. suppose I’ll tear one down real quick to see.
Christopher Monge - 回复
Looking at the speaker without thermal coverings looks like it just has some sound information. “8 ohm 0.5 w”. Next line, “1742 (space) 1”. Third line, “+ S -”.
Looks like electrical info of the speaker. I’ll keep looking!
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 15
总计 2,665
