跳转到主内容
Nest Cam Side Snap Locks Replacement
你所需要的
  1. Nest Cam Side Snap Locks Replacement, Side Snap Locks: 步骤 1 中的图像 1,1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Side Snap Locks Replacement: 步骤 2 中的图像 1,3 Nest Cam Side Snap Locks Replacement: 步骤 2 中的图像 2,3 Nest Cam Side Snap Locks Replacement: 步骤 2 中的图像 3,3
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Side Snap Locks Replacement: 步骤 3 中的图像 1,3 Nest Cam Side Snap Locks Replacement: 步骤 3 中的图像 2,3 Nest Cam Side Snap Locks Replacement: 步骤 3 中的图像 3,3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Side Snap Locks Replacement: 步骤 4 中的图像 1,2 Nest Cam Side Snap Locks Replacement: 步骤 4 中的图像 2,2
    • Remove the four 3 mm Phillips #J000 screws from the side snap locks. Remove the old side snap locks and place the new side snap locks.
    • Make sure everything lines up for the screws.
结论
Lisa Langley
于02/24/16注册
207 声望
撰写一个指南
团队
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G1
7 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 1,988
