跳转到主内容
加入维修社区 - 创建账户
Nest Cam Outdoor S Internal Camera Replacement
你所需要的
  1. Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: 步骤 1 中的图像 1,2 Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: 步骤 1 中的图像 2,2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Internal Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Internal Camera Replacement: 步骤 3 中的图像 1,1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Internal Camera Replacement: 步骤 4 中的图像 1,2 Nest Cam Outdoor S Internal Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Internal Camera Replacement, Internal Camera: 步骤 5 中的图像 1,1
    • Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
  6. Nest Cam Outdoor S Internal Camera Replacement: 步骤 6 中的图像 1,1
    • Remove the four mounting screws from the motherboard.
  7. Nest Cam Outdoor S Internal Camera Replacement: 步骤 7 中的图像 1,1
    • Disconnect the yellow camera cable from the motherboard.
    • Remove the camera from the device.
结论
2等其他人完成本指南。
Skylar DeVoe
于10/28/21注册
235 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G6
2 名成员
创作了4篇指南
2指南评论
Can you replace the corn to the actual camera
Cathy Willis - 回复 分享
Can you replace the corn to actual camera
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 2,214
