跳转到主内容
Nest Cam Outdoor S Battery Replacement
你所需要的
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: 步骤 1 中的图像 1,2 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: 步骤 1 中的图像 2,2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: 步骤 3 中的图像 1,1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: 步骤 4 中的图像 1,2 Nest Cam Outdoor S Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: 步骤 5 中的图像 1,2 Nest Cam Outdoor S Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
结论
另外一个人完成了本指南。
Phelix Gaudette
于10/28/21注册
275 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G6
2 名成员
创作了4篇指南
2条评论
Do you have the P/N of the battery??
Richard K Yabuki - 回复
Where to buy a replacement battery?
Ted McKenna - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 38
过去 30 天: 230
总计 6,544
