跳转到主内容
加入维修社区 - 创建账户
Nest Cam Mic Cable Replacement
你所需要的
  1. Nest Cam Mic Cable Replacement, Mic Cable: 步骤 1 中的图像 1,1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
    询问修复机器人
    添加评论
  2. Nest Cam Mic Cable Replacement: 步骤 2 中的图像 1,3 Nest Cam Mic Cable Replacement: 步骤 2 中的图像 2,3 Nest Cam Mic Cable Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
    询问修复机器人
    添加评论
  3. Nest Cam Mic Cable Replacement: 步骤 3 中的图像 1,1
    • Holding the back panel firmly, use a spudger to pry off the small plastic panel holding the mic cable in place.
    • Use a heat gun to melt the glue keeping the mic cable in place and then remove it.
    • During reassembly this plastic piece may need to be glued back on to ensure the mic cable stays in place on the back panel.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jade Weiss
于02/24/16注册
662 声望
创作了3篇指南
团队
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G1
7 名成员
创作了10篇指南
3指南评论
Thank you for this look inside the device. In the Nest settings there is a way to turn off the microphone, but anyone with access can turn it back on. I'm going to use this guide to unplug the microphone and permanently (but reversibly) disable it.
Bruce MacDonald - 回复 分享
Yes, by accessing the settings either via the app, or the website. Device options will all you to control the mic recording, or notifications if you just don't want to know when it picks up audio. Each app has its own settings on my devices, I think, but don't quote me on that one.
Be He - 回复 分享
Good job.
Do you have any idea if the cam doesn't restart?
Thanks.
Summer
summer - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 36
总计 4,317
