跳转到主内容
加入维修社区 - 创建账户
Nespresso Pixie Internal Diffuser Replacement
你所需要的
  1. Nespresso Pixie Internal Diffuser Replacement, Internal Diffuser: 步骤 1 中的图像 1,1
    • Unplug the machine from any outlets.
    • Remove the water tank by pressing the top button and pulling outwards.
    • Make sure there is no fluid left in any part of the machine.
  2. Nespresso Pixie Internal Diffuser Replacement: 步骤 2 中的图像 1,2 Nespresso Pixie Internal Diffuser Replacement: 步骤 2 中的图像 2,2
    • Use a Torx T5 screwdriver to detach the lever of the machine on both sides.
  3. Nespresso Pixie Internal Diffuser Replacement: 步骤 3 中的图像 1,1
    • Remove the drip tray using your hand.
  4. Nespresso Pixie Internal Diffuser Replacement: 步骤 4 中的图像 1,1
    • Use your hand to remove the black drip tray grill behind the drip tray.
  5. Nespresso Pixie Internal Diffuser Replacement: 步骤 5 中的图像 1,2 Nespresso Pixie Internal Diffuser Replacement: 步骤 5 中的图像 2,2
    • Use a Torx T4 screwdriver to unscrew each screw on the faceplates.
    • Remove the faceplate using a metal spudger.
    • Be sure to start in both corners to separate the pieces.
  6. Nespresso Pixie Internal Diffuser Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Locate the two springs in each top right corner and use a set of tweezers to remove them.
    • Be sure to set the machine in an enclosed container when this is done so as to not to lose the springs.
  7. Nespresso Pixie Internal Diffuser Replacement: 步骤 7 中的图像 1,1
    • Take off the white plastic bits using a metal spudger.
  8. Nespresso Pixie Internal Diffuser Replacement: 步骤 8 中的图像 1,2 Nespresso Pixie Internal Diffuser Replacement: 步骤 8 中的图像 2,2
    • Remove the clear plastic bits using a metal spudger.
    • Be sure to pull it out using the hole in which it is indented.
  9. Nespresso Pixie Internal Diffuser Replacement: 步骤 9 中的图像 1,1
    • Use your hands to remove the cables that give power to the machine.
  10. Nespresso Pixie Internal Diffuser Replacement: 步骤 10 中的图像 1,1
    • Use your hands to remove the water spout.
  11. Nespresso Pixie Internal Diffuser Replacement: 步骤 11 中的图像 1,2 Nespresso Pixie Internal Diffuser Replacement: 步骤 11 中的图像 2,2
    • Seperate both halves of the machine using both a spudger and your hands.
    • Once you have unclipped the side at the top, middle of the side and base. You can push with a screw driver through the hole on the reverse side to help remove the plastic side.
    • Be sure to take your time and start in the middle. Note that it is incredibly well secured.
  12. Nespresso Pixie Internal Diffuser Replacement: 步骤 12 中的图像 1,1
    • Use your hands to pull out the first lever housing in the spot shown in the picture.
  13. Nespresso Pixie Internal Diffuser Replacement: 步骤 13 中的图像 1,1
    • Pull the brewing mechanism apart from the remaining plastic barrier.
    • Once it is separated, pull off the other lever housing in the same way as was described in the previous step.
  14. Nespresso Pixie Internal Diffuser Replacement: 步骤 14 中的图像 1,2 Nespresso Pixie Internal Diffuser Replacement: 步骤 14 中的图像 2,2
    • Use a spudger to unclip the clips holding the black case in place.
    • Pull the brewing chamber outwards from the machine and then pull it downwards to detach it.
  15. Nespresso Pixie Internal Diffuser Replacement: 步骤 15 中的图像 1,2 Nespresso Pixie Internal Diffuser Replacement: 步骤 15 中的图像 2,2
    • Pry off the clips holding the inner white chamber in place in the machine.
  16. Nespresso Pixie Internal Diffuser Replacement: 步骤 16 中的图像 1,1
    • Use a spudger to take off your diffuser plate.
    • Insert your new diffuser plate.
结论
Drew
于11/05/23注册
260 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 的会员
UMASSD-GULBRANDSEN-F23S2G2
4 名成员
创作了13篇指南
1指南评论
I’m sorry but this tutorial should be removed. You’ll just going to broke parts by following that.
biorn - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 47
过去 30 天: 252
总计 4,141
