跳转到主内容
加入维修社区 - 创建账户
Nerf Zombie Strike Crossbow Trigger Spring Replacement
你所需要的
  1. Nerf Zombie Strike Crossbow Trigger Spring Replacement, Trigger Spring: 步骤 1 中的图像 1,1
    • There are 19 1.0 cm screws in total.
  2. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 步骤 2 中的图像 1,1
    • Separate each part of the Nerf crossbow.
  3. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 步骤 3 中的图像 1,1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 步骤 4 中的图像 1,1
    • Take the broken spring off of the trigger.
  5. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 步骤 5 中的图像 1,1
    • Replace it with the new spring you bought at your local hardware store.
  6. Nerf Zombie Strike Crossbow Trigger Spring Replacement: 步骤 6 中的图像 1,1
    • Now that the spring has been reattached to the trigger repeat step two.
    • Finish by performing steps two and three in reverse order.
结论
另外一个人完成了本指南。
团队
1指南评论
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 3,804
