跳转到主内容
Nerf Zombie Strike Crossbow Cocking Mechanism Replacement
你所需要的
  1. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement, Cocking Mechanism: 步骤 1 中的图像 1,1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 步骤 2 中的图像 1,1
    • The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
  3. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 步骤 3 中的图像 1,1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 步骤 4 中的图像 1,1
    • Separate each part of the Nerf crossbow.
  5. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 步骤 5 中的图像 1,1
    • Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
  6. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: 步骤 6 中的图像 1,1
    • The cocking device needs to be attached to the plunger in order to function properly.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 3,474
