跳转到主内容
Nerf Vortex Vigilon Clip Attachment Replacement
你所需要的
  1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide screws: 步骤 1 中的图像 1,1
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
  2. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide pieces: 步骤 2 中的图像 1,1
    • Lift both slide pieces off of the gun.
  3. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: 步骤 3 中的图像 1,2 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: 步骤 3 中的图像 2,2
    • Remove the twelve #00 1 cm Phillips screws.
    • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Rotate the gun so that the front is facing you to remove the final screw.
  4. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outside cover: 步骤 4 中的图像 1,1
    • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
    • The magazine will slide down automatically as you remove the cover.
  5. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: 步骤 5 中的图像 1,2 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: 步骤 5 中的图像 2,2
    • At the top left area of the gun, lift the clip towards you, and it will easily slide out.
结论
另外一个人完成了本指南。
Cara Pew
于09/29/14注册
911 声望
创作了7篇指南
团队
Cal Poly, Team 13-6, Forte Fall 2014 Cal Poly, Team 13-6, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G6
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 1,098
