简介
If any part of the trigger assembly breaks, this guide will show how to remove any problematic areas. A screwdriver with a long shaft will be needed to get to all of the screws. Also watch out for any small parts that may come apart and fall out as you're working on the device.
你所需要的
Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
结论
另外一个人完成了本指南。
