跳转到主内容
Nerf Recon CS-6 Barrel Replacement
你所需要的
  1. Nerf Recon CS-6 Barrel Replacement, Remove Magazine: 步骤 1 中的图像 1,1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Nerf Recon CS-6 Barrel Replacement, Remove Visible Screws: 步骤 2 中的图像 1,1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 Barrel Replacement, Remove Hidden Screws: 步骤 3 中的图像 1,2 Nerf Recon CS-6 Barrel Replacement, Remove Hidden Screws: 步骤 3 中的图像 2,2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Nerf Recon CS-6 Barrel Replacement, Remove Plunger Cap: 步骤 4 中的图像 1,1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 Barrel Replacement, Remove Slide Screws: 步骤 5 中的图像 1,1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 Barrel Replacement, Split the Gun in Half: 步骤 6 中的图像 1,2 Nerf Recon CS-6 Barrel Replacement, Split the Gun in Half: 步骤 6 中的图像 2,2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
  7. Nerf Recon CS-6 Barrel Replacement, Remove Spring: 步骤 7 中的图像 1,2 Nerf Recon CS-6 Barrel Replacement, Remove Spring: 步骤 7 中的图像 2,2
    • Pull the spring out the back of the gun.
  8. Nerf Recon CS-6 Barrel Replacement, Removing Plunger Guide: 步骤 8 中的图像 1,1
    • Lift the plunger guide straight up out of the gun.
  9. Nerf Recon CS-6 Barrel Replacement, Remove Plunger: 步骤 9 中的图像 1,1
    • Pull the plunger out the back of the gun off of the inner piece.
  10. Nerf Recon CS-6 Barrel Replacement, Remove  Other Half of Plunger: 步骤 10 中的图像 1,1
    • Pull the remaining half of the plunger out the back of the gun.
结论
6等其他人完成本指南。
Pam Ruffner
于10/20/14注册
984 声望
创作了3篇指南
团队
Baylor, Team 8-14, Williams Fall 2014 Baylor, Team 8-14, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G14
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 4,572
