跳转到主内容
Nerf N-Strike Firestrike LED Replacement
你所需要的
  1. Nerf N-Strike Firestrike LED Replacement, Blaster Casing: 步骤 1 中的图像 1,1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  2. Nerf N-Strike Firestrike LED Replacement: 步骤 2 中的图像 1,2 Nerf N-Strike Firestrike LED Replacement: 步骤 2 中的图像 2,2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  3. Nerf N-Strike Firestrike LED Replacement: 步骤 3 中的图像 1,2 Nerf N-Strike Firestrike LED Replacement: 步骤 3 中的图像 2,2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  4. Nerf N-Strike Firestrike LED Replacement, Remove battery cover: 步骤 4 中的图像 1,1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  5. Nerf N-Strike Firestrike LED Replacement: 步骤 5 中的图像 1,2 Nerf N-Strike Firestrike LED Replacement: 步骤 5 中的图像 2,2
    • Slide out the two AAA batteries using your fingers.
  6. Nerf N-Strike Firestrike LED Replacement, Laser Trigger: 步骤 6 中的图像 1,2 Nerf N-Strike Firestrike LED Replacement, Laser Trigger: 步骤 6 中的图像 2,2
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
  7. Nerf N-Strike Firestrike LED Replacement, Laser Assembly: 步骤 7 中的图像 1,1
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
  8. Nerf N-Strike Firestrike LED Replacement: 步骤 8 中的图像 1,3 Nerf N-Strike Firestrike LED Replacement: 步骤 8 中的图像 2,3 Nerf N-Strike Firestrike LED Replacement: 步骤 8 中的图像 3,3
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
  9. Nerf N-Strike Firestrike LED Replacement, LED: 步骤 9 中的图像 1,2 Nerf N-Strike Firestrike LED Replacement, LED: 步骤 9 中的图像 2,2
    • Pinch the clips holding the laser beam casing to the circuit board with your fingers. Slide off the casing revealing the LED.
  10. Nerf N-Strike Firestrike LED Replacement: 步骤 10 中的图像 1,1
    • Use a soldering iron to heat up the two connections holding the LED to the circuit board. Remove the LED.
结论
6等其他人完成本指南。
Hayes Kimball
于04/19/15注册
742 声望
创作了5篇指南
团队
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G6
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 19
总计 3,090
