跳转到主内容
Nerf N-Strike Firestrike Firing Trigger Replacement
你所需要的
  1. Nerf N-Strike Firestrike Firing Trigger Replacement, Remove battery cover: 步骤 1 中的图像 1,1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Firing Trigger Replacement: 步骤 2 中的图像 1,2 Nerf N-Strike Firestrike Firing Trigger Replacement: 步骤 2 中的图像 2,2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Firing Trigger Replacement, Blaster Casing: 步骤 3 中的图像 1,1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Firing Trigger Replacement: 步骤 4 中的图像 1,2 Nerf N-Strike Firestrike Firing Trigger Replacement: 步骤 4 中的图像 2,2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Firing Trigger Replacement: 步骤 5 中的图像 1,2 Nerf N-Strike Firestrike Firing Trigger Replacement: 步骤 5 中的图像 2,2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: 步骤 6 中的图像 1,2 Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: 步骤 6 中的图像 2,2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
结论
4等其他人完成本指南。
Jong Wan Kim
于04/22/15注册
422 声望
创作了2篇指南
团队
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 2,993
