跳转到主内容
修复你的物品
维修的权力
商店
简介
This spring piston mechanism acts as the primary form of energy storage for your blaster to fire darts. When the blaster is cocked, the air-tight piston mechanism is pulled back and the large spring is compressed, holding in potential energy. Once the blaster is triggered, the energy from the spring pushes the piston forward towards the front of the blaster. Because the piston is air-tight against the walls of the chamber, it pushes all of the air out towards the opening in the front. As this air exits the chamber, it then pushes the dart out of the barrel. If any issues exist with this device, it is usually with the chamber being air-tight. If any air is allowed to exit otherwise, it greatly reduces the effectiveness of the blaster.
  1. Lay the Nerf Strongarm on its side, left side facing up. Lay the Nerf Strongarm on its side, left side facing up.
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Locate the 12 Philips head screws and remove them:  Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm Locate the 12 Philips head screws and remove them:  Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. At this time, remove the blaster cover to reveal its internals.
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Once the screws have been removed, lift the top half of the gun off.
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
  6. First, remove the outer parts of the blaster, starting with the top part of the cocking mechanism. Then remove the full cover itself. First, remove the outer parts of the blaster, starting with the top part of the cocking mechanism. Then remove the full cover itself.
    • First, remove the outer parts of the blaster, starting with the top part of the cocking mechanism. Then remove the full cover itself.
  7. Remove the barrel and the front part of the blaster. The components should simply slide off. Remove the barrel and the front part of the blaster. The components should simply slide off.
    • Remove the barrel and the front part of the blaster. The components should simply slide off.
  8. Remove the screw on the inside of the gun.
    • Remove the screw on the inside of the gun.
    • Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  9. Remove the trigger, the cocking holdback, and the air compressor chamber Remove the trigger, the cocking holdback, and the air compressor chamber Remove the trigger, the cocking holdback, and the air compressor chamber
    • Remove the trigger, the cocking holdback, and the air compressor chamber
  10. Remove the spring holding the air compressor together.
    • Remove the spring holding the air compressor together.
  11. Remove the spring air compressor component.
    • Remove the spring air compressor component.
  12. This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work. This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work. This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work.
    • This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work.
结论
7等其他人完成本指南。
Dylan Cooper Dalrymple
于2015年01月15日注册
720 信誉积分
创作了3篇指南
团队
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G4
4 名成员
创作了11篇指南
mi nerf strongarm no dispara los dardos con la misma potencia que cuando la utilice por primera vez, dispara los dardos demasiado suave
juanestebanlopezcastrillon - 回复
Maybe the problem is the dards.
Álvaro Sousa PT -
My nerf elite disruptor's drum some times working but sometimes notworkin
Skm - 回复
what is the size of the spring?
JoseRafael - 回复
添加评论
浏览统计数据:
过去的24小时: 12
过去的7天: 47
过去的30天: 264
总计 23,036
