跳转到主内容
Nerf N-Strike Elite Strongarm Main Spring Replacement
你所需要的
  1. Nerf N-Strike Elite Strongarm Main Spring Replacement, Main Spring: 步骤 1 中的图像 1,1
    • Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
  2. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 2 中的图像 1,1
    • From the base, lift the action and the trigger.
  3. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 3 中的图像 1,1
    • Lift the Nerf dart cylinder and the firing mechanism (spring chamber).
  4. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 4 中的图像 1,3 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 4 中的图像 2,3 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 4 中的图像 3,3
    • Unscrew screws (2) from the cylinder rotator mechanism.
  5. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 5 中的图像 1,1
    • Remove the air plunger and the spring from inside the chamber.
  6. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 6 中的图像 1,3 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 6 中的图像 2,3 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 6 中的图像 3,3
    • Turn the spring counter-clockwise to free the spring. Be careful at the beginning and the end of the process.
  7. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 7 中的图像 1,3 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 7 中的图像 2,3 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 7 中的图像 3,3
    • Replace the spring.
    • The spring will be greasy. Don’t be alarmed. Be careful at the beginning and the end of the process because it is like getting a key ring on at the notches, particularly at the top of the chamber.
    • Tip: If dry, use a little vegetable oil on the O-ring before putting it back.
  8. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 8 中的图像 1,1
    • Return the plunger to the spring chamber.
  9. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 9 中的图像 1,2 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 9 中的图像 2,2
    • Screw the cover back onto the cylinder rotator.
  10. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 10 中的图像 1,1
    • Place the spring chamber and the Nerf bullet cylinder back into the base.
  11. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 11 中的图像 1,2 Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 11 中的图像 2,2
    • Screw the trigger and the action back in. Swing the gray gun charging slide out when putting the action back in.
  12. Nerf N-Strike Elite Strongarm Main Spring Replacement: 步骤 12 中的图像 1,1
    • Secure the cover and the charging slide with the 12 screws.
结论
5等其他人完成本指南。
Robert
于03/18/15注册
192 声望
撰写一个指南
4条评论
Where can I buy a replacement spring?
mike580358 - 回复
you can get a replacement or an upgrade spring at the website www.nfstrike.com
NEW CHANNEL -
When I put it back together it did not work
autisteck - 回复
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
tiderfish - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 55
总计 16,263
