跳转到主内容
加入维修社区 - 创建账户
Nerf N-Strike Elite Strongarm Barrel Replacement
你所需要的
    1. Nerf N-Strike Elite Strongarm Barrel Replacement, Outer Shell: 步骤 1 中的图像 1,2 Nerf N-Strike Elite Strongarm Barrel Replacement, Outer Shell: 步骤 1 中的图像 2,2
      • Lay the Nerf Strongarm on its side, left side facing up.
      询问修复机器人
      添加评论
    2. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 2 中的图像 1,2 Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 2 中的图像 2,2
      • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
      询问修复机器人
      添加评论
    3. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 3 中的图像 1,1
      • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
      • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
      询问修复机器人
      添加评论
    4. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 4 中的图像 1,1
      • At this time, remove the blaster cover to reveal its internals.
      • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
      询问修复机器人
      添加评论
    5. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 5 中的图像 1,1
      • Once the screws have been removed, lift the top half of the gun off.
      • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
      • Take care and try not to lose any smaller pieces as you open it up.
      • Locking tab for attachments.
      添加评论
    1. Nerf N-Strike Elite Strongarm Barrel Replacement, Barrel: 步骤 6 中的图像 1,1
      • Start by inspecting the barrel closer for broken components.
      • Pressing the unloading button is a good test to check if the barrel will rotate out.
      • If the barrel fails to cooperate, continue onto the next steps.
      询问修复机器人
      添加评论
    2. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 7 中的图像 1,1
      • Once the cover is off, the barrel component will be free and removable.
      询问修复机器人
      添加评论
    3. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 8 中的图像 1,1
      • Once the barrel is removed, continue by removing the front shaft. This component is also independent of the blaster and does not require tools.
      询问修复机器人
      添加评论
    4. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 9 中的图像 1,1
      • Look for any signs of debris or any damaged locations that may be causing the barrel to lock.
      询问修复机器人
      添加评论
    5. Nerf N-Strike Elite Strongarm Barrel Replacement: 步骤 10 中的图像 1,1
      • At this time, all components interacting with the barrel are removed.
      • Take this time to inspect the barrel for any signs of debris or damaged locations.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
团队
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S5G4
4 名成员
创作了17篇指南
1指南评论
hi my barrel keeps ritating and is not fixed and does not stay aligned to the shooting point what shall i do
cryo17 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 46
总计 13,412
