跳转到主内容
Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
你所需要的
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: 步骤 1 中的图像 1,2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: 步骤 1 中的图像 2,2
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 2 中的图像 1,1
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 3 中的图像 1,3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 3 中的图像 2,3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 3 中的图像 3,3
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 4 中的图像 1,3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 4 中的图像 2,3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 4 中的图像 3,3
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 5 中的图像 1,3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 5 中的图像 2,3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 5 中的图像 3,3
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 6 中的图像 1,2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: 步骤 6 中的图像 2,2
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 46
总计 2,946
