跳转到主内容
Nerf N-Strike Elite Retaliator Spring Replacement
你所需要的
  1. Nerf N-Strike Elite Retaliator Spring Replacement, Case Disassembly: 步骤 1 中的图像 1,1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Spring Replacement: 步骤 2 中的图像 1,1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Spring Replacement: 步骤 3 中的图像 1,1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Spring Replacement: 步骤 4 中的图像 1,2 Nerf N-Strike Elite Retaliator Spring Replacement: 步骤 4 中的图像 2,2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Spring Replacement: 步骤 5 中的图像 1,2 Nerf N-Strike Elite Retaliator Spring Replacement: 步骤 5 中的图像 2,2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: 步骤 6 中的图像 1,2 Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: 步骤 6 中的图像 2,2
    • The spring may be compressed. If so, carefully release spring pressure before proceeding.
    • While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
结论
11等其他人完成本指南。
ericharman
于03/02/16注册
1,410 声望
创作了5篇指南
2条评论
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
Ryan Zhang - 回复
can i use a nerf kronos spring
jordan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 12,665
