本指南有最近更改,您可查看未经巡查的最新版本。
简介
A worn plunging mechanism can limit your effective firing range. Nobody has time for that. Use this guide to disassemble the blaster and replace the plunger and air chamber.
你所需要的
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
16等其他人完成本指南。
4条评论
Where did we found the pièces??
where i can buy for spare part “air chamber”?
this tutorial helped A LOT
