跳转到主内容
Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement
你所需要的
  1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Case Disassembly: 步骤 1 中的图像 1,1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
    What about a drum mag how do you remove that
    Alex Leadbeater - 回复
  4. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 4 中的图像 1,2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 4 中的图像 2,2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 5 中的图像 1,2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
    Itd be nice if we got a pic comparing the internals to an old yellow nerf recon (if you have one). I wonder how much changes between generations.
    sigoshi - 回复
    Removed every screw and gun does not separate. not showing the seperation of the gun makes this tutorial completely useless.
    Jeff Glover - 回复
    You have to remove the thing you use to ready it
    Daniel MacDonald -
    It would be nice if you could color-code where to put the 16mm, 10mm and 8mm screws. That way, you don’t wind up damaging the screw post or stripping a screw by trying to insert a 10mm screw into a post meant for an 8mm one.
    SirMikay - 回复
    it's very helpful that the troubleshooting for slider won't move backwards goes to "Another two must be removed with the sliding mechanism in the back position." How, just how do you do that if it's jammed
    Adrian Tennies - 回复
    please help if you can
    Adrian Tennies -
    definitely not angry at the troubleshooting page
    Adrian Tennies -
  6. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Air Chamber: 步骤 6 中的图像 1,1
    • The firing spring may be energized. If so, carefully release and spring pressure before proceeding.
    • While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
  7. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 7 中的图像 1,1
    • Slide the white air chamber forward and remove the white alignment bracket.
  8. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
结论
16等其他人完成本指南。
ericharman
于03/02/16注册
1,410 声望
创作了5篇指南
4条评论
Where did we found the pièces??
Albert Einstein - 回复
where i can buy for spare part “air chamber”?
sabeni83_king - 回复
this tutorial helped A LOT
Daniel MacDonald - 回复
OK I've removed the air chamber now what?
camper234 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 60
总计 19,957
