简介
Keep your aim sharp by replacing the motor.
你所需要的
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
With your gun disassembled, locate the motor around the front portion of your gun as shown in Figure 1. Remove the two 9.0 mm Phillips screws securing the top shell of the motor casing.
With the shell now removed, locate the motor and controlling circuit board. With your index finger and thumb, squeeze the holders shown in Figure 2 and pull upwards to release the motor module from the rest of the motor's casing. Your motor should be detached from the casing, as shown in Figure 3.
6等其他人完成本指南。
4条评论
Where do I get the motor from. I have a Nerf Demolisher 2 in 1 and I want to see if the place you buy it from has a motor for it.
If you are still looking for the motors, you could check if any of these work with your model http://www.containmentcrew.com/product-c... . They are motors used often by people adding power to their motorized blasters, however, you may need a more powerful battery such as a LiPo or Nihm H.
