跳转到主内容
Nerf N-Strike Elite Hail-Fire Battery Replacement
你所需要的
  1. Nerf N-Strike Elite Hail-Fire Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Nerf N-Strike Elite Hail-Fire Battery Replacement: 步骤 2 中的图像 1,1
    • Pull the battery compartment out and away from the gun.
  3. Nerf N-Strike Elite Hail-Fire Battery Replacement: 步骤 3 中的图像 1,1
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Nerf N-Strike Elite Hail-Fire Battery Replacement: 步骤 4 中的图像 1,1
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. Nerf N-Strike Elite Hail-Fire Battery Replacement: 步骤 5 中的图像 1,1
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
结论
6等其他人完成本指南。
Jonathan Peck
于01/24/14注册
217 声望
撰写一个指南
团队
Cal Poly, Team 13-13, Regan Winter 2014 Cal Poly, Team 13-13, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G13
4 名成员
创作了7篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 93
总计 25,680
