当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
Be sure that the rifle is discharged and unloaded before starting disassembly.
With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Separate and remove the two halves of the slide mechanism.
Make sure to keep track of which screws correspond to which holes.
Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
Remove the two 5 mm phillips screws from the main body.
Remove the two 8 mm phillips screws from the main body.
Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
Pull the two halves of the rifle apart.
Be careful of the spring at the rear end of the rifle. It may come flying out.
If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
Also be careful of small parts when opening the gun, they may be easy to lose.
Remove the access gate and barrel cover.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
