跳转到主内容
Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement
你所需要的
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Notes Before Starting: 步骤 1 中的图像 1,1
    • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • Be sure that the rifle is discharged and unloaded before starting disassembly.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Rear Cap Removal: 步骤 2 中的图像 1,3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Rear Cap Removal: 步骤 2 中的图像 2,3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Rear Cap Removal: 步骤 2 中的图像 3,3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Slide Removal: 步骤 3 中的图像 1,3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Slide Removal: 步骤 3 中的图像 2,3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Slide Removal: 步骤 3 中的图像 3,3
    • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 步骤 4 中的图像 1,2 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 步骤 4 中的图像 2,2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 步骤 5 中的图像 1,3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 步骤 5 中的图像 2,3 Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement: 步骤 5 中的图像 3,3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement, Spring Removal: 步骤 6 中的图像 1,1
    • You should now be able to pull the main firing spring from the rear of the rifle.
结论
2等其他人完成本指南。
Henrique Chan
于01/24/14注册
303 声望
创作了2篇指南
团队
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G35
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 19
总计 6,645
