跳转到主内容
简介
A damaged barrel may negatively accuracy and overall performance of your rifle. in severe cases it may prevent your rifle from firing all together. This guide shows you how to access and replace the barrel of the Nerf gun.
配件
没有特定配件。
  1. Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle. Pull off the orange cap. Pull off the orange cap.
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  2. With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together. Remove the three 10 mm phillips screws from the bottom of the slide mechanism. Separate and remove the two halves of the slide mechanism.
    • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  3. Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle. Remove the two 5 mm phillips screws from the main body.
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  4. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  5. Pull the two halves of the rifle apart. Be careful of the spring at the rear end of the rifle. It may come flying out. If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  6. Remove the two 5mm phillips screws from the rifle muzzle. Remove the two 5mm phillips screws from the rifle muzzle.
    • Remove the two 5mm phillips screws from the rifle muzzle.
  7. Remove the muzzle and barrel from the rifle body.
    • Remove the muzzle and barrel from the rifle body.
  8. Separate the muzzle from the barrel.
    • Separate the muzzle from the barrel.
结论
另外一个人完成了本指南。
Elizabeth Coffey
于2014年01月26日注册
380 信誉积分
创作了3篇指南
团队
Cal Poly, Team 10-35, Maness Winter 2014 Cal Poly, Team 10-35, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G35
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 12
过去的30天: 92
总计 4,093
