跳转到主内容
Nerf Dart Tag Furyfire Large Spring Replacement
你所需要的
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: 步骤 1 中的图像 1,1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: 步骤 2 中的图像 1,1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: 步骤 3 中的图像 1,1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: 步骤 4 中的图像 1,2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: 步骤 4 中的图像 2,2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
结论
Bradley Penrow
于09/23/14注册
37 声望
创作了4篇指南
团队
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 1,408
