跳转到主内容
Necklace Barrel Clasp Repair
你所需要的
  1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: 步骤 1 中的图像 1,2 Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: 步骤 1 中的图像 2,2
    • Locate the broken part of the ring that attaches through the back of the barrel clasp.
    • Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
  2. Necklace Barrel Clasp Repair: 步骤 2 中的图像 1,1
    • Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
    • The soldering iron tip can get extremely hot and will cause severe burns if comes into direct contact with skin. Ensure you keep a safe distance, and wear safety equipment.
    • This method is not recommended for precious metals.
  3. Necklace Barrel Clasp Repair: 步骤 3 中的图像 1,1
    • Molten metal is extremely hot and will cause severe burns. Handle the soldering gun with care and keep your distance from the melting metal.
    • Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
    • Ensure the barrel clasp and ring connection is covered, allowing anywhere from 10 to 30 seconds for the bond to harden and cool.
  4. Necklace Barrel Clasp Repair: 步骤 4 中的图像 1,1
    • Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
    • Do not pull too hard—the amount of strain may cause the solder to break.
结论
Garrett Key
于07/12/17注册
107 声望
撰写一个指南
团队
Texas Tech, Team S1-G5, Rauch Summer 2017 Texas Tech, Team S1-G5, Rauch Summer 2017 的会员
TTU-RAUCH-SU17S1G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 2,724
