跳转到主内容
Neato XV-21 Wheels Replacement
你所需要的
  1. Neato XV-21 Wheels Replacement, Back Panels of Neato XV-21: 步骤 1 中的图像 1,1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Wheels Replacement: 步骤 2 中的图像 1,1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Wheels Replacement: 步骤 3 中的图像 1,1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Wheels Replacement, Battery: 步骤 4 中的图像 1,1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Wheels Replacement, Wheels: 步骤 5 中的图像 1,1
    • Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
  6. Neato XV-21 Wheels Replacement: 步骤 6 中的图像 1,1
    • Slide out dowel rod connecting the wheel to the robot.
  7. Neato XV-21 Wheels Replacement: 步骤 7 中的图像 1,2 Neato XV-21 Wheels Replacement: 步骤 7 中的图像 2,2
    • Lift the wheel so the spring is exposed
    • Pay particular attention to how the wheel is placed to replicate during reinsertion
    • Unhook the spring from robot
    • Lift the wheel from the cavity
结论
3等其他人完成本指南。
一条评论
Needs to Link to Parts List and a way to Order Parts.
Bill Price - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 699
