跳转到主内容
Neato XV-21 Fan Replacement
你所需要的
  1. Neato XV-21 Fan Replacement, Back Panels of Neato XV-21: 步骤 1 中的图像 1,1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Fan Replacement: 步骤 2 中的图像 1,1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Fan Replacement: 步骤 3 中的图像 1,1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Fan Replacement, Battery: 步骤 4 中的图像 1,1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Fan Replacement, Fan: 步骤 5 中的图像 1,2 Neato XV-21 Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
    • Once the wires are disconnected lift the fan from the cavity
  6. Neato XV-21 Fan Replacement: 步骤 6 中的图像 1,1
    • Once the fan has been removed you can take a damp cloth and clean the cavity before attaching the new device
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,134
