跳转到主内容
Neato XV Signature Wheel Assembly Replacement
你所需要的
  1. Neato XV Signature Wheel Assembly Replacement, Wheel Assembly: 步骤 1 中的图像 1,1
    • Place the Neato with the bottom side facing up.
  2. Neato XV Signature Wheel Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the four machine screws securing the main compartment plate using a Phillips #0 screwdriver.
  3. Neato XV Signature Wheel Assembly Replacement: 步骤 3 中的图像 1,2 Neato XV Signature Wheel Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove the main compartment plate, exposing the wheel axis and fan.
  4. Neato XV Signature Wheel Assembly Replacement: 步骤 4 中的图像 1,1
    • Lift up on the wheel axis to remove the axle bar from its clasp.
  5. Neato XV Signature Wheel Assembly Replacement: 步骤 5 中的图像 1,2 Neato XV Signature Wheel Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the axle bar from the wheel mount, exposing the suspension spring.
  6. Neato XV Signature Wheel Assembly Replacement: 步骤 6 中的图像 1,2 Neato XV Signature Wheel Assembly Replacement: 步骤 6 中的图像 2,2
    • Unlatch the suspension spring from the wheel mount, exposing the wheel connector cable.
  7. Neato XV Signature Wheel Assembly Replacement: 步骤 7 中的图像 1,1
    • Unplug the wheel connector cable.
    • Repeat steps 4-7 with the other wheel.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 191
