跳转到主内容
Neato XV Signature Motor Assembly Replacement
你所需要的
  1. Neato XV Signature Motor Assembly Replacement, Motor Assembly: 步骤 1 中的图像 1,2 Neato XV Signature Motor Assembly Replacement, Motor Assembly: 步骤 1 中的图像 2,2
    • Flip your Neato XV Signature robot over so that so are looking at the underside of it.
  2. Neato XV Signature Motor Assembly Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips head #2 screwdriver, unscrew the four 14 mm (1.4 cm) screws on the external panel that covers the motor assembly.
    • Be sure not to lose the screws.
  3. Neato XV Signature Motor Assembly Replacement: 步骤 3 中的图像 1,2 Neato XV Signature Motor Assembly Replacement: 步骤 3 中的图像 2,2
    • Use plastic spudger to gently pry off the external panel to expose the motor assembly.
  4. Neato XV Signature Motor Assembly Replacement: 步骤 4 中的图像 1,2 Neato XV Signature Motor Assembly Replacement: 步骤 4 中的图像 2,2
    • Gently lift the motor assembly straight up, out of place, being aware of the four mounting posts that hold the motor firmly in place.
  5. Neato XV Signature Motor Assembly Replacement: 步骤 5 中的图像 1,3 Neato XV Signature Motor Assembly Replacement: 步骤 5 中的图像 2,3 Neato XV Signature Motor Assembly Replacement: 步骤 5 中的图像 3,3
    • Press the tab and gently lift straight up to disconnect the motor wires.
  6. Neato XV Signature Motor Assembly Replacement: 步骤 6 中的图像 1,3 Neato XV Signature Motor Assembly Replacement: 步骤 6 中的图像 2,3 Neato XV Signature Motor Assembly Replacement: 步骤 6 中的图像 3,3
    • After disconnecting the wire clip, remove the motor assembly out of the compartment.
    • With the replacement motor, you can now begin reassembly.
结论
To finish connecting the new motor assembly, follow these steps in reverse order. Be sure to replace the back external panel and four screws to tightly secure.
Emily Cardella
于02/10/17注册
104 声望
撰写一个指南
团队
USF Tampa, Team 15-5, Remmell Spring 2017 USF Tampa, Team 15-5, Remmell Spring 2017 的会员
USFT-REMMELL-S17S15G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,389
