跳转到主内容
Neato Botvac D8000 Wheel Replacement
你所需要的
  1. Neato Botvac D8000 Wheel Replacement, Brushes: 步骤 1 中的图像 1,1
    • Place the vacuum on its back so the brushes are visible.
  2. Neato Botvac D8000 Wheel Replacement: 步骤 2 中的图像 1,3 Neato Botvac D8000 Wheel Replacement: 步骤 2 中的图像 2,3 Neato Botvac D8000 Wheel Replacement: 步骤 2 中的图像 3,3
    • Remove the four 10 mm screws with a Torx T10 screwdriver.
  3. Neato Botvac D8000 Wheel Replacement: 步骤 3 中的图像 1,2 Neato Botvac D8000 Wheel Replacement: 步骤 3 中的图像 2,2
    • Remove the rotary brush simply by grabbing it firmly and pulling it off.
    • Once you have removed your rotary brush and 4 bolts, you can easy remove the brush guard.
  4. Neato Botvac D8000 Wheel Replacement: 步骤 4 中的图像 1,2 Neato Botvac D8000 Wheel Replacement: 步骤 4 中的图像 2,2
    • Remove the brush by simply pulling it out.
    • From there you can clean it or replace the brush with a new one.
  5. Neato Botvac D8000 Wheel Replacement, Top Face Panel: 步骤 5 中的图像 1,1
    • Grab the rear bumper with both hands on either side.
  6. Neato Botvac D8000 Wheel Replacement: 步骤 6 中的图像 1,2 Neato Botvac D8000 Wheel Replacement: 步骤 6 中的图像 2,2
    • Firmly pull the bumper forward at a steady pace.
    • When pulling the bumper forward avoid being too rough because the bumper might break.
  7. Neato Botvac D8000 Wheel Replacement: 步骤 7 中的图像 1,2 Neato Botvac D8000 Wheel Replacement: 步骤 7 中的图像 2,2
    • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
  8. Neato Botvac D8000 Wheel Replacement: 步骤 8 中的图像 1,3 Neato Botvac D8000 Wheel Replacement: 步骤 8 中的图像 2,3 Neato Botvac D8000 Wheel Replacement: 步骤 8 中的图像 3,3
    • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
  9. Neato Botvac D8000 Wheel Replacement: 步骤 9 中的图像 1,3 Neato Botvac D8000 Wheel Replacement: 步骤 9 中的图像 2,3 Neato Botvac D8000 Wheel Replacement: 步骤 9 中的图像 3,3
    • Push the clips, located in the back side, inward.
    • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
    • When you lift the top cover be careful because the wires are thin and fragile.
  10. Neato Botvac D8000 Wheel Replacement: 步骤 10 中的图像 1,1
    • Once you have carefully removed the wire clip; you can fully remove the top cover.
  11. Neato Botvac D8000 Wheel Replacement, Wheel: 步骤 11 中的图像 1,3 Neato Botvac D8000 Wheel Replacement, Wheel: 步骤 11 中的图像 2,3 Neato Botvac D8000 Wheel Replacement, Wheel: 步骤 11 中的图像 3,3
    • Locate the screws that mount the wheel extension to the Robot.
    • Unscrew the four 11mm screws indicated with a Torx T10 screwdriver to remove the frame.
    • Make sure to remove the metallic weight. However, this does not require the removal of any screws.
  12. Neato Botvac D8000 Wheel Replacement: 步骤 12 中的图像 1,3 Neato Botvac D8000 Wheel Replacement: 步骤 12 中的图像 2,3 Neato Botvac D8000 Wheel Replacement: 步骤 12 中的图像 3,3
    • Delicately lift up the frame holding the laser. This will access the wheels.
    • Detach the wheel wires that are connected to the motherboard.
    • Once the wires are detached, the wheel are free from their casing.
  13. Neato Botvac D8000 Wheel Replacement: 步骤 13 中的图像 1,2 Neato Botvac D8000 Wheel Replacement: 步骤 13 中的图像 2,2
    • Use a Torx T15 screwdriver to remove the 32.5mm screw.
    • Finally, just hold and separate the wheel from its axle.
结论
另外一个人完成了本指南。
Ruth Lopez
于03/22/18注册
280 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 34
总计 3,538
