跳转到主内容
Neato Botvac D8000 Top Face Panel Replacement
你所需要的
  1. Neato Botvac D8000 Top Face Panel Replacement, Top Face Panel: 步骤 1 中的图像 1,1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac D8000 Top Face Panel Replacement: 步骤 2 中的图像 1,2 Neato Botvac D8000 Top Face Panel Replacement: 步骤 2 中的图像 2,2
    • Firmly pull the bumper forward at a steady pace.
    • When pulling the bumper forward avoid being too rough because the bumper might break.
  3. Neato Botvac D8000 Top Face Panel Replacement: 步骤 3 中的图像 1,2 Neato Botvac D8000 Top Face Panel Replacement: 步骤 3 中的图像 2,2
    • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
  4. Neato Botvac D8000 Top Face Panel Replacement: 步骤 4 中的图像 1,3 Neato Botvac D8000 Top Face Panel Replacement: 步骤 4 中的图像 2,3 Neato Botvac D8000 Top Face Panel Replacement: 步骤 4 中的图像 3,3
    • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
  5. Neato Botvac D8000 Top Face Panel Replacement: 步骤 5 中的图像 1,3 Neato Botvac D8000 Top Face Panel Replacement: 步骤 5 中的图像 2,3 Neato Botvac D8000 Top Face Panel Replacement: 步骤 5 中的图像 3,3
    • Push the clips, located in the back side, inward.
    • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
    • When you lift the top cover be careful because the wires are thin and fragile.
  6. Neato Botvac D8000 Top Face Panel Replacement: 步骤 6 中的图像 1,1
    • Once you have carefully removed the wire clip; you can fully remove the top cover.
结论
2等其他人完成本指南。
Ruth Lopez
于03/22/18注册
280 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 923
