跳转到主内容
Neato Botvac D8000 Brushes Replacement
你所需要的
  1. Neato Botvac D8000 Brushes Replacement, Brushes: 步骤 1 中的图像 1,1
    • Place the vacuum on its back so the brushes are visible.
  2. Neato Botvac D8000 Brushes Replacement: 步骤 2 中的图像 1,3 Neato Botvac D8000 Brushes Replacement: 步骤 2 中的图像 2,3 Neato Botvac D8000 Brushes Replacement: 步骤 2 中的图像 3,3
    • Remove the four 10 mm screws with a Torx T10 screwdriver.
  3. Neato Botvac D8000 Brushes Replacement: 步骤 3 中的图像 1,2 Neato Botvac D8000 Brushes Replacement: 步骤 3 中的图像 2,2
    • Remove the rotary brush simply by grabbing it firmly and pulling it off.
    • Once you have removed your rotary brush and 4 bolts, you can easy remove the brush guard.
  4. Neato Botvac D8000 Brushes Replacement: 步骤 4 中的图像 1,2 Neato Botvac D8000 Brushes Replacement: 步骤 4 中的图像 2,2
    • Remove the brush by simply pulling it out.
    • From there you can clean it or replace the brush with a new one.
结论
Yeritza Quiroz
于03/22/18注册
159 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 706
