跳转到主内容
Neato Botvac D8000 Battery Replacement
你所需要的
  1. Neato Botvac D8000 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Neato Botvac D8000 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the robot upside down to locate the battery cover.
  2. Neato Botvac D8000 Battery Replacement: 步骤 2 中的图像 1,3 Neato Botvac D8000 Battery Replacement: 步骤 2 中的图像 2,3 Neato Botvac D8000 Battery Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to unscrew both of the 20mm screws.
    • Gently lift the battery cover.
    • Remove the battery cover to reveal the battery.
  3. Neato Botvac D8000 Battery Replacement: 步骤 3 中的图像 1,3 Neato Botvac D8000 Battery Replacement: 步骤 3 中的图像 2,3 Neato Botvac D8000 Battery Replacement: 步骤 3 中的图像 3,3
    • Use a flathead screwdriver to push down on the latch of the battery clip.
    • Simultaneously, pull on the battery while pushing down on the latch to detach the battery from the clip.
    • Do not pull on the wires that are connected to the battery.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 11
总计 812
