跳转到主内容
Neato Botvac D75 Brushes Replacement
你所需要的
  1. Neato Botvac D75 Brushes Replacement, Brushes: 步骤 1 中的图像 1,3 Neato Botvac D75 Brushes Replacement, Brushes: 步骤 1 中的图像 2,3 Neato Botvac D75 Brushes Replacement, Brushes: 步骤 1 中的图像 3,3
    • To remove the rotary brush simply grasp it firmly and pull it off.
  2. Neato Botvac D75 Brushes Replacement: 步骤 2 中的图像 1,3 Neato Botvac D75 Brushes Replacement: 步骤 2 中的图像 2,3 Neato Botvac D75 Brushes Replacement: 步骤 2 中的图像 3,3
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  3. Neato Botvac D75 Brushes Replacement: 步骤 3 中的图像 1,1
    • Once the black piece has been taken out, the brush just comes out easily.
结论
Juan Cornejo
于02/15/17注册
597 声望
创作了5篇指南
团队
USF Tampa, Team S6-G5, Lacy Spring 2017 USF Tampa, Team S6-G5, Lacy Spring 2017 的会员
USFT-LACY-S17S6G5
4 名成员
创作了10篇指南
一条评论
I have removed and cleaned the brush but it still won't run due to the error message to clean the brush. The machine has only run 5 or 6 times so brand new machine.
keytkey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 915
