跳转到主内容
Neato Botvac D75 Battery Replacement
你所需要的
  1. Neato Botvac D75 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Neato Botvac D75 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Neato Botvac D75 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
    • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
  2. Neato Botvac D75 Battery Replacement: 步骤 2 中的图像 1,3 Neato Botvac D75 Battery Replacement: 步骤 2 中的图像 2,3 Neato Botvac D75 Battery Replacement: 步骤 2 中的图像 3,3
    • Lift battery cover out.
  3. Neato Botvac D75 Battery Replacement: 步骤 3 中的图像 1,3 Neato Botvac D75 Battery Replacement: 步骤 3 中的图像 2,3 Neato Botvac D75 Battery Replacement: 步骤 3 中的图像 3,3
    • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
    • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
结论
另外一个人完成了本指南。
Juan Cornejo
于02/15/17注册
597 声望
创作了5篇指南
团队
USF Tampa, Team S6-G5, Lacy Spring 2017 USF Tampa, Team S6-G5, Lacy Spring 2017 的会员
USFT-LACY-S17S6G5
4 名成员
创作了10篇指南
一条评论
Thanks for the tuto.
an additionnal info when having a battery issue, is to the reset to new battery. enter the menu, then help, and chose new battery.
it seems the neato system is set for planned obsolescence… unfortunatly for customers….
so I did it because battery stayed empty while plugged and switch found ok . And new my botvac is ok, like new!!
Nom - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 24
总计 2,147
