跳转到主内容
Neato Botvac 80 Top Face Panel Replacement
你所需要的
  1. Neato Botvac 80 Top Face Panel Replacement, Rear Bumper: 步骤 1 中的图像 1,1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac 80 Top Face Panel Replacement: 步骤 2 中的图像 1,1
    • Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
  3. Neato Botvac 80 Top Face Panel Replacement, Top Face Panel: 步骤 3 中的图像 1,2 Neato Botvac 80 Top Face Panel Replacement, Top Face Panel: 步骤 3 中的图像 2,2
    • Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
  4. Neato Botvac 80 Top Face Panel Replacement: 步骤 4 中的图像 1,1
    • Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
  5. Neato Botvac 80 Top Face Panel Replacement: 步骤 5 中的图像 1,3 Neato Botvac 80 Top Face Panel Replacement: 步骤 5 中的图像 2,3 Neato Botvac 80 Top Face Panel Replacement: 步骤 5 中的图像 3,3
    • To remove the top, you must press in both of the clamps at the same time and push upwards.
    • When removing the top, before you can completely take it off you must unplug the LCD power cable from the motherboard.
结论
2等其他人完成本指南。
Brandon Blank
于02/02/17注册
675 声望
创作了5篇指南
团队
USF Tampa, Team 17-5, Blackwell Spring 2017 USF Tampa, Team 17-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 914
