跳转到主内容
Neato Botvac 80 Laser Replacement
你所需要的
  1. Neato Botvac 80 Laser Replacement, Rear Bumper: 步骤 1 中的图像 1,1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac 80 Laser Replacement: 步骤 2 中的图像 1,1
    • Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
  3. Neato Botvac 80 Laser Replacement, Top Face Panel: 步骤 3 中的图像 1,2 Neato Botvac 80 Laser Replacement, Top Face Panel: 步骤 3 中的图像 2,2
    • Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
  4. Neato Botvac 80 Laser Replacement: 步骤 4 中的图像 1,1
    • Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
  5. Neato Botvac 80 Laser Replacement: 步骤 5 中的图像 1,3 Neato Botvac 80 Laser Replacement: 步骤 5 中的图像 2,3 Neato Botvac 80 Laser Replacement: 步骤 5 中的图像 3,3
    • To remove the top, you must press in both of the clamps at the same time and push upwards.
    • When removing the top, before you can completely take it off you must unplug the LCD power cable from the motherboard.
  6. Neato Botvac 80 Laser Replacement, Laser: 步骤 6 中的图像 1,3 Neato Botvac 80 Laser Replacement, Laser: 步骤 6 中的图像 2,3 Neato Botvac 80 Laser Replacement, Laser: 步骤 6 中的图像 3,3
    • Lift gently upon the top panel.
    • Unplug the clip located on the right side before completely removing.
  7. Neato Botvac 80 Laser Replacement: 步骤 7 中的图像 1,3 Neato Botvac 80 Laser Replacement: 步骤 7 中的图像 2,3 Neato Botvac 80 Laser Replacement: 步骤 7 中的图像 3,3
    • This black cap spins so may need a hand when unscrewing the screws.
    • Locate and unscrew the four 12 mm screws located in the black cap with the phillips #00 screwdriver.
    • Lift the black cap to reveal the laser.
  8. Neato Botvac 80 Laser Replacement: 步骤 8 中的图像 1,3 Neato Botvac 80 Laser Replacement: 步骤 8 中的图像 2,3 Neato Botvac 80 Laser Replacement: 步骤 8 中的图像 3,3
    • There are two loosely secured black blinders on both the laser and sensor.
    • Gently pull back on the gold laser to remove it from the socket.
    • Unplug the mini LCU clip by gently pulling up and remove the laser.
结论
4等其他人完成本指南。
Brandon Blank
于02/02/17注册
675 声望
创作了5篇指南
团队
USF Tampa, Team 17-5, Blackwell Spring 2017 USF Tampa, Team 17-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G5
3 名成员
创作了12篇指南
9条评论
lol. You don’t need to open it to replace the laser. The top is a clip on. Just pull it and remove 4 screws.
Evgany Vorona - 回复
where do you buy the replacement laser?
Nancy Butler - 回复
I too would like to know where he got a replacement laser.
Anthony Mainini -
where do I buy a replacement laser?
bjurgensen79@gmail.com
Beverly Jurgensen
Beverly Jurgensen - 回复
Where do I buy a replacement laser?
Beverly Jurgensen
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 26
总计 8,981
