跳转到主内容
Neato Botvac 80 Brush Replacement
你所需要的
  1. Neato Botvac 80 Brush Replacement, Remove Small Wheels: 步骤 1 中的图像 1,2 Neato Botvac 80 Brush Replacement, Remove Small Wheels: 步骤 1 中的图像 2,2
    • Note: This step is not necessaryto remove the brush guard. Only do this is the wheels are not spinning correctly To begin, turn the Neato Botvac 80 upside down and locate the brush. Remove the 4 screws highlighted in red, and remove the cover. This releases the 2 small wheels, where you can remove the hair that gets tangled in them.
    • You will need to remove the four 10mm bolts with a T10 Torx screwdriver.
  2. Neato Botvac 80 Brush Replacement: 步骤 2 中的图像 1,1
    • Find the two inlays in front of the wheels and pull them to release the brush guard.
  3. Neato Botvac 80 Brush Replacement, Remove Brush: 步骤 3 中的图像 1,1
    • Remove brush by pulling out and to the side.
    • If you want to replace: repeat these steps in reverse with the new brush bar
    • If you want to clean: take the metal bearing off the side, remove the hair wrapped in the orange holder. With a scissors, cut the hair out of the brush roll. Re-insert the brushroll and re-install the brush guard
结论
另外一个人完成了本指南。
Brandon Blank
于02/02/17注册
675 声望
创作了5篇指南
团队
USF Tampa, Team 17-5, Blackwell Spring 2017 USF Tampa, Team 17-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 2,393
