跳转到主内容
Neato Botvac 80 Battery Replacement
你所需要的
  1. Neato Botvac 80 Battery Replacement, Loosening screws: 步骤 1 中的图像 1,3 Neato Botvac 80 Battery Replacement, Loosening screws: 步骤 1 中的图像 2,3 Neato Botvac 80 Battery Replacement, Loosening screws: 步骤 1 中的图像 3,3
    • First, open the bin compartment and flip the switch to the off position.
    • Once you have done this, flip the robot over. Loosen the 2 screws, and lift the flap off
    • You will need to remove the 22.5mm bolts with a J1 Torx screwdriver.
    • Screws cannot be removed from the cover.
  2. Neato Botvac 80 Battery Replacement, Remove battery cover: 步骤 2 中的图像 1,2 Neato Botvac 80 Battery Replacement, Remove battery cover: 步骤 2 中的图像 2,2
    • Gently lift to remove battery cover.
  3. Neato Botvac 80 Battery Replacement, Removing battery: 步骤 3 中的图像 1,3 Neato Botvac 80 Battery Replacement, Removing battery: 步骤 3 中的图像 2,3 Neato Botvac 80 Battery Replacement, Removing battery: 步骤 3 中的图像 3,3
    • Locate battery clip.
    • Press down on latch with thumb and slide clip back.
    • Remove the battery.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 17-5, Blackwell Spring 2017 USF Tampa, Team 17-5, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 30
总计 4,970
