跳转到主内容
Neato BOTVAC D5 Li-ion Battery Replacement
你所需要的
  1. Neato BOTVAC D5 Li-ion Battery Replacement, Li-ion Battery: 步骤 1 中的图像 1,2 Neato BOTVAC D5 Li-ion Battery Replacement, Li-ion Battery: 步骤 1 中的图像 2,2
    • Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
    • Unscrew the two 24 mm captive screws holding the battery compartment shut.
    • They will not come out of the cover, since the battery is the most replaced part. They are located right under the main brush.
  2. Neato BOTVAC D5 Li-ion Battery Replacement: 步骤 2 中的图像 1,2 Neato BOTVAC D5 Li-ion Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully pull the battery out of it's socket so you can clearly see the wires connecting it to the robot.
    • Carefully unplug the connection, freeing the battery.
结论
Elijah Baker
于10/30/23注册
220 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-3, Konn Fall 2023 UMass Dartmouth, Team 3-3, Konn Fall 2023 的会员
UMASSD-KONN-F23S3G3
4 名成员
创作了5篇指南
一条评论
What is each function of the wires that come out of the D5 14.4V 6.5a h 93.6 Wh battery?
Red-_________
White-_________
Black-_________
Black-_________
Blue-_________
Yellow-_________
sells-glisten0k@icloud.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 205
