跳转到主内容
Neato BOTVAC CONNECTED Front Roller Brush Replacement
你所需要的
  1. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 2 中的图像 1,2 Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 2 中的图像 2,2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 3 中的图像 1,2 Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 3 中的图像 2,2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 4 中的图像 1,3 Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 4 中的图像 2,3 Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 4 中的图像 3,3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 5 中的图像 1,1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: 步骤 6 中的图像 1,2 Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: 步骤 6 中的图像 2,2
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 7 中的图像 1,1
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 8 中的图像 1,1
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 9 中的图像 1,1
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Front Roller Brush Replacement: 步骤 10 中的图像 1,1
    • Gently remove the front brush.
结论
Justin Silva
于03/20/23注册
645 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-3, Botvin Spring 2023 UMass Dartmouth, Team 6-3, Botvin Spring 2023 的会员
UMASSD-BOTVIN-S23S6G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 110
