跳转到主内容
Nanit Pro N301 Camera Replacement
你所需要的
  1. Nanit Pro N301 Camera Replacement, Camera: 步骤 1 中的图像 1,3 Nanit Pro N301 Camera Replacement, Camera: 步骤 1 中的图像 2,3 Nanit Pro N301 Camera Replacement, Camera: 步骤 1 中的图像 3,3
    • Insert an opening pick into the seam between the front and rear case.
    • Slide the opening pick around the perimeter of the camera until all of the retaining clips are released.
    • Separate the front and rear case.
  2. Nanit Pro N301 Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the four 4 mm T6 Torx screws from each corner of the circuit board.
    • Lift the circuit board out of the chassis.
  3. Nanit Pro N301 Camera Replacement: 步骤 3 中的图像 1,3 Nanit Pro N301 Camera Replacement: 步骤 3 中的图像 2,3 Nanit Pro N301 Camera Replacement: 步骤 3 中的图像 3,3
    • Remove the rubber gasket around the camera.
  4. Nanit Pro N301 Camera Replacement: 步骤 4 中的图像 1,1
    • Disconnect the white camera connector from the circuit board.
    • Do not pull on the wires.
  5. Nanit Pro N301 Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the small Phillips screw that secures the camera.
  6. Nanit Pro N301 Camera Replacement: 步骤 6 中的图像 1,2 Nanit Pro N301 Camera Replacement: 步骤 6 中的图像 2,2
    • Remove the filter from behind the camera lens.
  7. Nanit Pro N301 Camera Replacement: 步骤 7 中的图像 1,2 Nanit Pro N301 Camera Replacement: 步骤 7 中的图像 2,2
    • Use a T4 Torx screwdriver to remove the screws that secure the computer chip to the white plastic bracket.
  8. Nanit Pro N301 Camera Replacement: 步骤 8 中的图像 1,1
    • Gently pull the circuit board away from the white plastic bracket.
  9. Nanit Pro N301 Camera Replacement: 步骤 9 中的图像 1,2 Nanit Pro N301 Camera Replacement: 步骤 9 中的图像 2,2
    • Use a Phillips screwdriver to remove the two screws that secure the underside of the camera.
  10. Nanit Pro N301 Camera Replacement: 步骤 10 中的图像 1,1
    • Gently lift the camera up and off the circuit board.
结论
2等其他人完成本指南。
Ryan Maher
于04/02/24注册
211 声望
撰写一个指南
团队
IUPUI, Team 3-1, Harley Spring 2024 IUPUI, Team 3-1, Harley Spring 2024 的会员
IUPUI-HARLEY-S24S3G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 72
