简介
If your Nanit Pro N301 is not producing a clear image or any image at all, use this guide to replace the camera lens. Some of the pieces are very small so make sure you have a tool that can grab tiny materials if you are unable to do so with your fingers. Make your device is not plugged in and connected to a power source during the repair.
你所需要的
Insert an opening pick into the seam between the front and rear case.
Slide the opening pick around the perimeter of the camera until all of the retaining clips are released.
Separate the front and rear case.
2等其他人完成本指南。
