跳转到主内容
加入维修社区 - 创建账户
Nail Clipper Reassembly
  1. Nail Clipper Reassembly, Nail Clipper Reassembly: 步骤 1 中的图像 1,3 Nail Clipper Reassembly, Nail Clipper Reassembly: 步骤 1 中的图像 2,3 Nail Clipper Reassembly, Nail Clipper Reassembly: 步骤 1 中的图像 3,3
    • Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
    • The side of the rod with the notch should be inserted first.
    • Note: The top of the clipper body will often have a pick/file attached to it. If no pick/file is present, either side can serve as the top or the bottom.
  2. Nail Clipper Reassembly: 步骤 2 中的图像 1,1
    • Compress the body of the clippers to reveal the notch.
  3. Nail Clipper Reassembly: 步骤 3 中的图像 1,1
    • Rotate the rod until the notch opening faces away from the body.
    • This allows for easier completion of the following step.
  4. Nail Clipper Reassembly: 步骤 4 中的图像 1,3 Nail Clipper Reassembly: 步骤 4 中的图像 2,3 Nail Clipper Reassembly: 步骤 4 中的图像 3,3
    • Place the hole of the lever into the revealed rod notch.
    • Release the compressed nail clipper body to lock the lever into place.
    • Note: Position of the lever does not matter at this point.
  5. Nail Clipper Reassembly: 步骤 5 中的图像 1,3 Nail Clipper Reassembly: 步骤 5 中的图像 2,3 Nail Clipper Reassembly: 步骤 5 中的图像 3,3
    • Swivel the lever into its normal position, and test the nail clippers' functionality.
结论
If you follow these steps, your nail clippers should be back to working order.
90等其他人完成本指南。
Robert Weber
于04/09/15注册
2,149 声望
撰写一个指南
团队
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 的会员
CPSU-GREEN-S15S30G5
5 名成员
创作了32篇指南
32指南评论
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
marvin - 回复
Thank you. Knew it was simple! Love this website.
jonathanl.aguiar - 回复
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
Albert E - 回复
That's why it says reassembly 🤨
Blake Jordan-Borns -
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
Tanya Bishop - 回复
添加评论
浏览统计数据:
过去 24 小时: 47
过去 7 天: 326
过去 30 天: 1,546
总计 147,520
