跳转到主内容
Nabi Jr Screen Replacement
你所需要的
  1. Nabi Jr Screen Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Screen Replacement: 步骤 2 中的图像 1,1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Screen Replacement: 步骤 4 中的图像 1,1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Screen Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
  6. Nabi Jr Screen Replacement: 步骤 6 中的图像 1,1
    • De-solder the grey wire from motherboard
  7. Nabi Jr Screen Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to peel off all yellow tape from the motherboard
    • Yellow tape is used in all locations where there is ribbon cable present.
  8. Nabi Jr Screen Replacement: 步骤 8 中的图像 1,2 Nabi Jr Screen Replacement: 步骤 8 中的图像 2,2
    • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
    • Pull black locking tabs up in opposite direction of ribbon cable to remove.
    • Use tweezers to pull the ribbon cable out of the locking tab's slot
  9. Nabi Jr Screen Replacement: 步骤 9 中的图像 1,2 Nabi Jr Screen Replacement: 步骤 9 中的图像 2,2
    • Lift motherboard to separate it the from the case shell.
  10. Nabi Jr Screen Replacement, Screen: 步骤 10 中的图像 1,1
    • Remove the 6 screws that hold the screen in place
  11. Nabi Jr Screen Replacement: 步骤 11 中的图像 1,2 Nabi Jr Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the screen from the front casing
  12. Nabi Jr Screen Replacement: 步骤 12 中的图像 1,1
    • Separate the screen from the plastic casing.
  13. Nabi Jr Screen Replacement: 步骤 13 中的图像 1,1
    • Replace the old screen with the new screen
结论
另外一个人完成了本指南。
Jimmy Nguyen
于03/24/15注册
271 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G3
3 名成员
创作了12篇指南
3条评论
Do you know of anywhere I can send a nabi jr to have a cracked screen replaced?
Katie - 回复
Yes thank you for the information but where do we find a screen to replace this?
davemel - 回复
My navi jr is the nick jr edition and looks a bit different inside. I replaced the screen, as mentioned here but has to remove the outter glass-like screen that has the second smaller ribbonattach from the original screen, and put it on my screen because the new screen did not have that part. All buttons work, the screen looks perfect and vibrant, but the EFEN TOUCH Does not work!!! What did I do wrong? I attached all the ribbons properly!!!
vane.lpz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 5,505
